I'm sorting out my "new" 1964 Challenger and I have discovered that both the heater blower and the windshield wipers only work on low speed. This is with the rocker switches in the center position. Putting either in the high speed position has the same result as putting it in off. I am not much with electrical stuff but my theory is that in both cases it is probably the rocker switch that is faulty. But is there anything else I should try?
No High Speed Heater Blower and Wipers
Electrical: No High Speed Heater Blower and Wipers
Bill Jackameit
1964 Challenger Wagonaire
1964 Daytona Sedan
Total of 10 Studebakers owned since 1961
Bill Jackameit's Studebaker Page online since October 1995
https://billstudepage.homestead.com/files/studpg.htm
sigpicTags: None
I notice in the wiring diagram that there is a both a fuze and a circuit breaker in the circuits for blower and wipers.
My Hawk has a toggle that is neutral in the center, up for high speed , low position for low speed. If rockers are the same.
I would suspect either or both fuse and breaker. Don't know why you are getting motion from neutral position. Check the grounds,
fuze and breaker. Then,if you have a jumper wire,put 12 volts directly to motors and see if you get the two speeds.
Good LuckThe 1950 Champion Starlight
Santa Barbara
CA
Two bad switches, both being bad in the same way sounds really weird to me. Read your wiring diagram and look under the dash. If you're really incapable of understanding the wiring diagram, ask another Stude nut in the area to look over the dash. It's entirely possible that somewhere in the last half century a previous owner had a problem and did a home brewed repair.'63 Lark Custom, 259 v8, auto, child seat
there is no comparison to the rocker vs. toggle switches: they work differently. As stated above, you have wiring and/or switch issues.....I suspect the switches unless you see some hanging or tied up wires or a lot of Rube's black tape under the dash. My 63' switches sometimes operate on one speed or the other...I simply keep flipping them on and off until the contacts free up....I haven't taken one apart, I'm sure they are a simple working, but maybe with "Jesus" spring(s) inside.......?
Rocker Switches
Originally posted by jackb View Postthere is no comparison to the rocker vs. toggle switches: they work differently. As stated above, you have wiring and/or switch issues.....I suspect the switches unless you see some hanging or tied up wires or a lot of Rube's black tape under the dash. My 63' switches sometimes operate on one speed or the other...I simply keep flipping them on and off until the contacts free up....I haven't taken one apart, I'm sure they are a simple working, but maybe with "Jesus" spring(s) inside.......?
I also noted that the instrument lights only come on at the high setting on their rocker switch -- the low setting does not turn them on -- but this may be correct for this car -- it is a Challenger which lacks some of the features of the more expensive models -- as far as I can tell there is no separate rheostat under the dash on the left side for the instrument lights. The rocker switch for the parking lights/headlights works as advertised.Last edited by bjackameit; 04-25-2011, 04:00 AM.Bill Jackameit
1964 Daytona Sedan
Originally posted by bjackameit View PostI also noted that the instrument lights only come on at the high setting on their rocker switch -- the low setting does not turn them on -- but this may be correct for this car -- it is a Challenger which lacks some of the features of the more expensive models -- as far as I can tell there is no separate rheostat under the dash on the left side for the instrument lights. The rocker switch for the parking lights/headlights works as advertised.
Joesigpic
1962 Daytona
1964 Cruiser
And a few others
What the heck is a "Jesus" spring?????!!
Also see: Bezel window and door handle Jesus clips1964 Studebaker Commander R2 clone
Lights fixed heater/defroster still a problem.
Originally posted by irish View PostI believe even the Challengers came with the rheostat under the dash, the rheostat is usually the problem with the instrument lights. I have owned several Studebakers that had the rheostat removed or disconnected. Also be sure and check your wiring connections at the switches.
JoeBill Jackameit
1964 Daytona Sedan
I had all these problems (almost identical to yours) in my 63' Cruiser......I found the problem with the heater motor was a bad internal wiring. It also had a spliced-in wire and would work on one speed only. Since I had several extra motors, I swapped a good double speed one in with good strong air flowand wires......However, I did need to replace the duct work to the defrosters.....Smartest thing I did for this winter. Also, and just for the "perfectionists" in the crowd......
Replacement fan motor for '63 to '66 Lark types/
That is great, but no help unless we know what part number and source the Ford or Jeep? fan motor was.StudeRich
Two speeds for Single Speed Heater Motor
Originally posted by jackb View PostI had all these problems (almost identical to yours) in my 63' Cruiser......I found the problem with the heater motor was a bad internal wiring. It also had a spliced-in wire and would work on one speed only. Since I had several extra motors, I swapped a good double speed one in with good strong air flowand wires......However, I did need to replace the duct work to the defrosters.....Smartest thing I did for this winter. Also, and just for the "perfectionists" in the crowd......Bill Jackameit
1964 Daytona Sedan
