Help needed with the AC-2302 rear seat speaker grill
It looks like the clips are just pushed on. If it was me, to keep from bending/damaging the mesh, I would take a thin ziz-wheel (cutoff wheel) in a rotary air grinder (or maybe a small dremel-type tool) and very carefully cut off one of the two 'tabs' on each clip. You will have to get some new clips but those are available in a number of diferent styles.Paul
Winston-Salem, NC
Originally posted by 55cmndr View Post[ATTACH=CONFIG]8855[/ATTACH][ATTACH=CONFIG]8854[/ATTACH]
Here are the pictures of the front and back of the speaker grill.
Any help with this is appreciated
55CMNDR
Care fully grab the outside of the clips with needle nosed pliers and twist and pull.JDP Maryland
The clips on the two studs are "friction nuts" and I remove them with a right angle dental pick or scribe. Slide the tip of the pick into the gaps of the friction nut so that the spring steel bends away from the stud ( not too hard) and they will come off. I sanded the Studebaker S with very fine sandpaper (500 grit +) to remove the pits and then painted with rattle can gold.
Regards,John Brayton
Most any body shop that's been around for a while has those clips in several sizes.Brad Johnson,
'56 Sky Hawk in process
The "S" was originally gold plated. There are some home plating kits on the market but the job only looks as good as the surface underneath and by now that is often pitted up. Thus paint works pretty well.
Back some years ago several vendors had just the "S" in stock as NOS. It has its own part number.
