I've got a '64 Daytona with a Chevy 283 swap. Recently I swapped out the 283 for a 350. Since the 350 engine came with a high torque starter I elected to use it. The solenoid on the 283 starter originally had:
1. Battery 12V + cable (large upper lug) connected with a red wire to power 12V + to the car.
2. A second large lug (lower) to connect directly to the starter.
3. A small lug White/red wire to energize the solenoid.
4. A small lug Green/black wire (to bypass the pink resistance wire) and send 12V to the coil only when the solenoid is energized.
My problem is the high torque GM starter is missing the connection for the Green/black wire as it was used in a Fuel Injected - Electronic Ignition car. Initially I connected the Green/black wire to the lower lug that only received power when the solenoid was energized. I figured this was only sending 12V to the coil when trying to start the car... (or was it?)
Then... (whack --- me slapping my head) I realized this was also pulling current to the starter through the linked pink resistance wire when the ignition was simply on!!! No wonder the coil had less than half a volt and the car wouldn't start.
Does it seem logical to just connect the Green/black wire to the White/red wire? This way the coil will still get 12V during cranking, but release voltage back through the pink resistance wire in the run position.
Stupid me again. This will only energize the solenoid and attempt to keep cranking. I now realize I need a relay... - or read later posts
The only drawback I see is that the 12V to the coil will go:
From the battery - through the ignition switch - then to the coil
Previously it went from the battery (via the solenoid) directly to the coil. There might be some voltage drop, but I doubt less that the resistance wire.
BTW I got it running by simply running 12V from battery to the coil +, but this is not a condition I should retain (I'm running a Pertronix module). Any input appreciated.
Thanks, Tom
Thanks, Tom
