28 president
I topped off the trans oil yesterday in my new car. it took a quart. this morning half the quart is on the floor. I found it to be leaking where the amoured housing meets the rigid shaft, 2 inches from the trans. I guess you know the question.....can that be repaired, do I need a cable,? I appreciate your help if you know the answer. David
(Should there be oil in the cable that far from the transmission, or is there a seal at the end of the cable allowing oil to get into it? )
