View Full Version : rear swaybar and reaction arm /rod
hawk gt 62 rhd
05-17-2007, 08:49 AM
Hello to you all,the next subject on my hawk gt is the installation of the above items I have seen the pictures in the forum last time
I have some options: from junk or original if I can find them.
Questions are about the measurements in/on the frame and the dimensions of the materials,thanks very much for your info
05-17-2007, 11:19 AM
I believe that Studebaker International carries the whole "kit".
05-17-2007, 05:27 PM
Or if you can find a mid-50s sedan parts car it will bolt right up (it's all the same stuff) make sure you get the spring plates too.
41 Frank
05-17-2007, 08:39 PM
Since this gentleman is located in Holland (my country of birth)it probably would be hard to find a parts car,best option is to purchase from S.I. or a vendor that has this used.
Frank van Doorn
