Okay, I've done several searches and can't find the answer to this. Frustrating thing is that this subject has been discussed here before.
I just had my OverDrive transmission ('56 Commander V8) rebuilt and when refilling it with oil have come up with a problem. I'll fill the front, then fill the rear, as per the manual. Thing is, when I fill the rear the front becomes over-full. If I allow the excess in the front to drain off, the rear (OverDrive housing) is empty. Shouldn't the two halves of the transmission (gear-box and OverDrive) be separate and sealed off from one another?
