My Lark has two sizable body problems: first is the almost completely eroded floor panels. I'm pretty sure I'll be able to weld in replacements easily enough.
HOWEVER, my concern is in my other problem: my driver's side door alignment is way off, and not by a small amount. I fear that if I weld in new floor pans and reinforce the posts that I'll just permanently seal the problem into the car. Take a look at the attached photos to see what I mean.
First, you can't see it because I took these pics with the door latched, but the whole door is sagging a little, probably 1/4 inch, give or take. It's not enough that the door won't latch, but you can feel the door lift up when it hits the striker. Also, look at how the door sits when closed. The top of the door is leaning way in, and the bottom leans way out.
How would I go about repairing these issues, and is it a matter of shimming, etc, or do I need to physically adjust the hinge post? With all the rust around it, it's possible that it's slightly off, but I'm not entirely convinced that the door was just re-mounted poorly years ago. Before the car went to go rest in a field for a decade and change, it had been stolen and taken for a joy ride in which the criminals sideswiped the vehicle. I believe my grandpa had removed the door and fender, and wound up hammering them out and replacing them on the car.
Thanks!
(The first image is just to illustrate the poor gap between the fender and the door, which was actually not only binding the door a bit, but was also causing the fender to bulge a bit.)
Thanks!
