View Full Version : coolant outlet gasket
vegas paul
05-15-2007, 09:10 PM
Pardon me if this sounds like too simple a question... but I've got a very slight coolant leak on the head (Champion 6) at the coolant outlet (thermostat housing) and I want to change the gasket to see if this stops it. Can I use any readily available (FLAPS) gasket material or do I need to order the specific part?
Is there a substitute or equivalent anyone knows of? Thanks.
Las Vegas, NV
http://i151.photobucket.com/albums/s144/vegas_paul/graciestude.jpghttp://i151.photobucket.com/albums/s144/vegas_paul/1462673_2_350.jpg
r1lark
05-16-2007, 12:40 PM
Las Vegas, NV
Yes, parts store gasket material will work, but you need to go with the thinner stuff. This is not a place for the really thick gasket material, especially with the amount of torque that gets put on those bolts. Use a little of your favorite gasket sealer on it (I used Permatex Aviation Form-a-Gasket, but this is real old tech.....just like me<G>!). Remember that there is also a round gasket under the thermostat 'ring'.....look at the parts book.
Also, the bolts holding the Champion thermostat housing on are head bolts, so they will need to be torqued to the spec in the Shop Manual.
Paul
Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
05-16-2007, 02:32 PM
Paul; the Thermostat "RING" that the other Paul mentions is very important! It is actually the thermostat "SPACER" and must be there, and in good shape with it's own gasket or the thermostat will leak internally.
It is best to order the correct gaskets: 194658, 194660. Or the complete kit with spacer, 801371 or 372, if you live in a cold climate.
Studebakers Northwest
Ferndale, WA
vegas paul
05-16-2007, 02:48 PM
Thanks - I ordered them from Studebaker International just now.
Las Vegas, NV
sbca96
05-16-2007, 05:16 PM
Nothing beats Permatex form-a-gasket No2 on both sides of a gasket. I
even use it on my 1995 Impala water neck due to corrosion in the alum
neck where the rubber gasket sits. Never had a leak after.;)
Tom
