I have a 1955 Commander coupe with a stock 259 V-8 engine, I have a chance to get an earlier trans off a 1951 Commander V-8, will it interchange to the later engine and body? Thanks for the help.
what trans works?
Tags: None
The '51 transmssion should be a T86, which your '55 Commander should have also. The transmission should interchange, with the possible exception of where the clutch shaft support bracket bolts to the bottom of the transmission case on the '55. I am not positive, but the '51 linkage may be different and thus the 'pad' where the support bracket bolts may not be machined flat & drilled/tapped. I ran into this when I used a '48 Commander T86 in my '54 sedan; everything was the same except I had to machine the pad flat and to the right height, and drill and tap for the two bolt holes.
A quick look in the parts book at the clutch linkage for '51 should tell the tale. Just something to look at, hopefully that '51 tranny will already be set up for the support bracket and you will be good to go.Paul
Winston-Salem, NC
Originally posted by bob1944 View PostI have a 1955 Commander coupe with a stock 259 V-8 engine, I have a chance to get an earlier trans off a 1951 Commander V-8, will it interchange to the later engine and body? Thanks for the help.Gary L.
Originally posted by studegary View PostEveryone is assuming that standard transmissions are what is being considered. I don't see where the question indicates the type of transmission. If both transmissions are automatic, it will interchange, but be an earlier version. If one is automatic and the other is standard, that is another story.
Hopefully he will check back and let us know.Paul
Winston-Salem, NC
Originally posted by royvaldez View PostA DG 250 M automatic trans willl work great for your 1951 project. This trans was year only in 1955. This will offer you 1st gear start. That transmission runs about $650.00Gary L.
Thanks I have the 2nd gear start now and it isn't too bad. Will pass on the 51 trans, it needs to be rebuilt so if I rebuild one it would be the 55 trans. the price looked good but if I have to spend money I'll keep the one I have. This forum is great lots of info to be had. Just ask. Again thank
