I have a full flow 289 used short block that I disassembled this winter. I have the block back from the machine shop and was getting ready to send them the crank. I thought it would be a good idea to record all the dimensions and clearances before I removed the timing gear from the crank. Upon close inspection I notice the shim pack for the thrust clearance is on the wrong side of the thrust washer! The motor appears to have been a running motor so I am a bit puzzeled. Anyone ever see this before?
Jon Kammer
Jon Kammer
