View Full Version : 61' Lark Oil Filter
61LaRk4dr
05-11-2007, 05:52 PM
Hello, another question.
I am going to add an oil filter assembly to the 61' lark I am working on. This is the spin on filter cartridge setup that has a base that mounts on the engine block. This car didn't come with this option originally so I am not sure just exactly where the lines go into the block.
Does anyone have a picture they could
show or e-mail that shows the line routing?
thank you
Dwain G.
05-12-2007, 01:18 PM
Are you going to search for a used filter assembly, or try to buy a new kit? The installation instruction sheet that came with a new kit is available from Dave Mottle. It doesn't have any illustrations, but does describe the installation very well.
Two things to watch out for. There should be a restrictor fitting (about .043") on the pressure side, otherwise enough oil will flow through this system to cause a drop in oil pressure.
Some of the early kits had an all aluminum base that would sometimes crack at the threads. Later ones have a threaded steel insert in the center.
http://home.comcast.net/~jdwain/63.63.jpg
Dwain G.
