How do you remove the key cylander
trunk lock
You have to have a correct Key, if you do, insert it in the Lock, push a paper clip in the small hole under the dust cover and remove the cylinder.StudeRich
Yep. Take it to a locksmith
I took out my back seat and crawled through with a flashligh and some tools. Pulled the clip and the lock fell out.
Took a little contorting, but it is not particularly difficult. Shoving aroung the spare and jack was the hardest part.sigpic 62 Hawk - Wisconsin barn find
There's a c-clip made of spring steel that slides between a groove in the housing and the metal of the trunk lid.A pair of pliers is usually all you need to wiggle it off the hsng. If your trunk is stuck closed,you could unbolt the latch from the rear panel using a socket,ratchet and a 3 or 4 foot extension,reaching thru the trunk from the backseat area [after the seat is out ]Oglesby,Il.
Originally posted by santa View PostI took out my back seat and crawled through with a flashligh and some tools. Pulled the clip and the lock fell out.
Took a little contorting, but it is not particularly difficult.Brad Johnson,
'56 Sky Hawk in process
