View Full Version : Master Cylinder
studecruiser
05-11-2007, 07:58 AM
I read in the repair manual that the dual reservoir MC were put on vehicles starting in 64, yet my 64 Cruiser has a single reservior MC. Which is correct and how difficult is it to change over to a dual as I like idea of having a back up in case something ruptures?
JDP
05-11-2007, 09:24 AM
If your Cruiser has disk brakes, the single is correct.
JDP/Maryland
63 GT R2
63 Avanti R1
63 Daytona convert-63
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
52 & 53 Starliner
51 Commander
05-11-2007, 09:33 AM
Here's a similar thread...
http://www.studebakerdriversclub.com/sdc_forum/topic.asp?TOPIC_ID=10256
Here's the ECI dual circuit remote booster...
http://www.ecihotrodbrakes.com/remote_booster.html
sbca96
05-11-2007, 08:48 PM
Yes, a Cruiser should have Avanti disc brakes and a single master. It
would be easy to just use the Avanti II style master cylinder and do
a split at the front Y-block. On my Avanti, I just plugged the port
for the rear brakes in the "Y", and used a union to extend the rear
brake line up to the dual master. You have a swinging pedal, so its
a simple task to add an electric brake light switch under the dash. I
recommend the bottom one on Bob Johnstones website :
http://www.studebaker-info.org/tech/repstuavMC.html
Mid 70's Chrysler. NAPA # 36307.
Item#: UP 36307
APR07
Price: $75.99
Bore Size:1 1/32"
Tom
