View Full Version : Has anyone installed a Hydraulic clutch in a Lark??
Dougie
02-26-2011, 11:56 AM
I'm looking for anyone with experience installing a hydraulic clutch in a Lark. My '62 is currently a 6 cylinder automatic and I'm switching to a Chevy V8 and Muncie 4 speed. I have a stock stick shift pedal assembly that I want to use and looking at the firewall it looks like it will be a very tight fit to get a Master cyliber in there. I also plan to change the single circut brake M/C to a dual, so won't be using the stock brake M/C. The stock brake M/C has a wide mounting flange because it bolts thru to the pedal assembly. If I use an aftermarket (like Wildwood) brake M/C, it may fit because it's narrower than the stock brake M/C. I have also thought about a remote reservoir for the clutch M/C but the space issue is still the same for the M/C itself.
Any thoughts or experience that anyoneshare will really be appreciated.
Alan
02-26-2011, 02:06 PM
I am in the middle of doing that now on a 63 T-cab.
Dougie
02-26-2011, 02:39 PM
How are planning to do it?
JDP
02-26-2011, 02:48 PM
The way I did it on a C-K was to add a matching master cylinder on the other side of the frame with a hydralic throwout bearing, piece of cake.
Alan
02-26-2011, 04:05 PM
I should have seen that it is a 62. Now those have through the floor pedals. My 63 has hanging pedals. But it is the same as Larks.
Dougie
02-26-2011, 07:16 PM
Nope. 62's also have the hanging pedals. It was the first year. Yours should be the same as mine.
N8N
02-26-2011, 08:38 PM
I think the way I've seen it done before is using a stock brake MC mounted inside the frame for the clutch... if you are using a Chevy/Muncie combo you ought to be able to find a bellhousing for a slave cylinder fairly easily, or just use a hydraulic release bearing... The latter might be easier although not as serviceable as if you use an aftermarket bellhousing it likely won't have the pad for the stock style rear engine mount.
Starlight
02-27-2011, 08:16 AM
Dougie, check your PM
bezhawk
02-27-2011, 04:20 PM
I don't know if you are aware, but, all the 61-up Lark type frames have the bracket on them to bolt stock mechanical linkage in place. (right behind the steering box).
Dougie
02-27-2011, 04:56 PM
I just checked and I see it. Now you're getting me to thinking.
