Gentleman, I tried the search option, but no help. I know its been discussed many times in TW, but to find it when you need it---- What current lubricant should be used in a TT differential? I have one can of TT lub from Studebaker, but don't want to mix something without knowing facts. Need enough to completly fill the diff. Thank you, Bob Fish
TT lubricant
Originally posted by feralcat0_0 View PostGentleman, I tried the search option, but no help. I know its been discussed many times in TW, but to find it when you need it---- What current lubricant should be used in a TT differential? I have one can of TT lub from Studebaker, but don't want to mix something without knowing facts. Need enough to completly fill the diff. Thank you, Bob FishJDP Maryland
There are additives available for use in TT differentials. Some of the gear oil suppliers have already added limited slip additive to their lube, so check the labeling as many of the lubes can be used as a factory fill of a limited slip differential without using an additive. Bud
