View Full Version : Front sway bar bushings
05-09-2007, 10:09 PM
Started the first baby step on my front-end teardown today by removing the sway bar. Lower a-arms were so caked up with grease and dirt inside it took 10 minutes just to find the bolt heads!
Question: how do you install the inner sway bar bushings? I couldn't get the old ones off going around that sharp bend in the bar; had to cut 'em off. Do you grease up the bar? Soap?
Clark in San Diego
'63 F2/Lark Standard
05-10-2007, 11:00 AM
Old bushings are often hard as a rock. New bushings should be more flexible. A clean sway bar, new bushings and a little silicone spray should do the deed. jv.
05-10-2007, 08:22 PM
Just DO NOT use silicone spary anywhere NEAR anything you might wanna put paint on one day.[8]
Miscreant adrift in
the BerStuda Triangle
05-14-2007, 10:40 AM
Tire lube or a soap product will make the bushings slippery and will wash off to allow painting.
!952 Champion Starlight since October,1971. !962 Daytona
since May, 2007.
