View Full Version : What is this ?
Stude Rookie
02-21-2011, 02:19 PM
I need some help identifying the tan round piece and an education as to what it and the tach plug into.
The three prong plug seems to indicate something special. Hopefully my pictures will upload. If not I will try again.http://zimbra The object in question is tan, round, about 3 5/8" in dia, Has a 3point plug in and a Key drive mechanism on the back side. Thanks,
Stude Rookie
02-21-2011, 02:49 PM
That sounds like theTach drive that goes between the Early Delco Distributor and the Dist. Cap on a Stude. V-8 Hawk from 1956 to 1961, you will need the matching Tach. head to plug it into.
JDP
02-21-2011, 02:55 PM
Stude Rookie
You need the tach harness, just a long extention cord with plugs and a ground and 12 volt wire, and the sender and special extension clips.
DEEPNHOCK
02-21-2011, 02:56 PM
Sounds like the tach drive assembly.
7485
Beige hockey puck sized part with a round tube in the middle you can spin with your fingers?
It gets sandwiched in between the distributor cap and distributor body.
The cap clips get short 'extensions' so the clips will still hook on to the cap.
Hooks to the tach lead that hooks to the tach...
7486
HTIH
Jeff:cool:
Stude Rookie
Stude Rookie
02-21-2011, 03:15 PM
Are the tach harness and special clips still available through Studebaker vendors or am I looking for unobtainium?
Stude Rookie
Stude Rookie
02-21-2011, 03:17 PM
7485
7486
HTIH
Jeff:cool:
Thank you for the pictures . That is exactly what I have, and now I am somewhat edicated. Will these parts work with an Avanti dual point distributor?
Stude Rookie
JDP
02-21-2011, 03:35 PM
Stude Rookie
No they will not fit, just a Delco, and yes the clips and harness are rare and not typical vendor stock.
Stude Rookie
02-21-2011, 03:55 PM
Looks as if I am stuck between a tach without a harness to the sender and a later model tach to my 56'GH dash. Thanks guys, I was at a loss. Not really sure what brand my Avanti distributor is either.
Stude Rookie
N8N
02-21-2011, 04:00 PM
well, a 56J used a Packard engine and Autolite dist (not the same as Avanti dual point tho) and used its own tach sender which looks the same as but is slightly different from the one used on Stude-engined cars with a Delco dist.
What's under your hood now? from your post it sounds like it's a Stude engine not Packard. If you want to use the stock tach sounds like you need to find a Delco non-window distributor and use the Delco sender, or a Prestolite dist. and use the 56J one (IF - and that is a big IF - it uses the same cap and rotor as a 56J dist, and I can't remember if it does or not.)
good luck
Stude Rookie
02-21-2011, 05:36 PM
good luck
Got my head to spinning now for sure. I grew up with small block Chevys and inter-changeability was a no brainer until the mid eighties. My Stude engine for this car is a 1963' R1 Avanti. I am slowly learning the intricasies of Studebaker ownership and have plenty of surprises to come I'm sure. Looks as if after market SW tach is the way to go on this one. I am working on other parts of the car since the Commanders rescue from the body shop so there is plenty to do. I will in all probability take the body off of the frame since it's all in pieces anyway. A step here, a step there. I love this car.
Stude Rookie
