View Full Version : Accelerator Sticking or Haunting?
Yesca
09-04-2006, 04:30 PM
Weirdness I have never experienced.......I believe my Lark is haunted. When accelerating the throttle will either stick, move on it`s own back and forth or accelerate without the peddle moving. This does not appear to be a linkage problem. everything looks square and I also cleaned the linkage and carb. I just rebuilt the carb a couple weeks ago.
Also... I need to find new linkage on the accelerator where that little ball joint is (next to the kick down terminal). That ball joint keeps popping off.
Thanks in advance,
Jason
dpson
09-04-2006, 04:54 PM
Check your throttle pull back springs. If it's a V-8 there should be two of them. If they are missing or weak your throttle could have a mind of it's own.
Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
1962 Lark V-8 Regal Convertible
JDP
09-04-2006, 04:56 PM
Sounds like a broken motor mount. When the engine rocks over it pulls the linkage. If it gets really bad, it'll flloor it and away you go. :)
http://stude.com/sig.jpg
Studebaker On The Net
http://stude.com
Studebaker News Group
Arnold Md.
65 Sports Sedan
64 Daytona HT
63 R2 4 speed GT Hawk
63 GT Hawk
63 Avanti R1/AC
63 Avanti R2/4 speed
63 Daytona HT
63 Lark 2 dr.
62 Lark 2 door
62 GT(parts car)
60 Lark convert
60 Hawk
52 Starliner
51 Commander
Yesca
09-04-2006, 05:33 PM
I think you are right, JDP. It feels as if the motor was moving after I hit the accelerator peddle. I off to check it out. The springs are in place and functioning fine Thanks,
Jason
N8N
09-04-2006, 06:23 PM
I agree with JDP, sure sounds like a motor mount. it's easier to tell on a 4-speed as you will be able to see the shifter stick move when you accelerate. If any mount is broken, it will be at least the driver's side front mount, that's the one that takes all the abuse when you accelerate, and it's also the one that would cause the symptoms you describe. Might as well replace them both while you're in there though. I broke two on my '62 before I just gave up and made my own with the rubber from some old mounts and a through bolt.
good luck,
60Lark
09-05-2006, 01:01 AM
It definately sounds like a broken motor mount
http://im1.shutterfly.com/procserv/47b6dc00b3127cce8b441ec7192c00000000100CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
Yesca
09-06-2006, 07:46 PM
*follow up*
The problem was the dust boot becoming unlodged and getting tangled in the linkage. Motor mounts good. Back on the road.
Thanks again!
Jason
