View Full Version : Edelbrock conversion
richnan
05-08-2007, 09:58 AM
Hi
Am putting a 1403 edelbrock on my 62 289.. Need to know which side to put the dist. vacuum line on.. I should have checked whether i have full vac at idle or at timed vacuum advance..Also any suggestions for a good spot for the choke wire hookup...
Thanks Dick
silver hawk
http://thumb15.webshots.com/t/55/155/1/78/69/2455178690029093115TDRPdQ_th.jpg
bige
05-08-2007, 10:47 AM
Pass side port for the advance, full 12 volts when the ignition is on, stay away from the distributor or coil as a source.
ErnieR
http://i146.photobucket.com/albums/r241/AvantiR2/avnatiglamour007.jpg
05-08-2007, 12:29 PM
Dick, the later Hawks have a Overdrive unused wire with terminal in the harness if the car is not equipped with overdrive, it works great. I don't have '57 Hawk to check to see if the older ones have it, but it would be hanging on the firewall behind the Left Cyl. head. If it has overdrive you could splice into the on-with ign. hot wire to the kickdown switch.
silver hawk
Studebakers Northwest
Ferndale, WA
Mike Van Veghten
05-08-2007, 02:39 PM
richnan -
See my note on the other (general) forum.
Note to all...no electricity required!
richnan
05-09-2007, 11:39 AM
Thanks Much Too All For The Info ..... Dick
silver hawk
