Does anyone know if the SI shifter boot, #1339521, for 61-64 Larks & Hawks w/4 speed would fit the '63 Champ? Would figure the Champ shifter opening in the floor would be the same as the Lark.
Champ Floor Shifter Boot
Does your '63 Champ have a truck 4-speed? If it does, then most likely the car 4-speed boot won't just 'interchange'.
If you have retrofitted a T-10 4-speed in your '63 Champ, it might if you used the fibreglass tower and have the chrome retainder that holds the boot down to the 'glass tower.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
I used an 80's Chevy truck shifter boot for my Champ 4 speed (not the T-10 type). Dont know on their availability now that most trucks are made with automatics.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
The Champ was modified from column 3-speed to floor 3-speed (no hange in the trans itself), and the stick is in the opening on the side of the trans hump where the 4-speed would have gone, I believe...? May be easiest to find and try a 80 Chevy truck boot at the salvage yard to start. Thanks for the help.
Originally posted by GTCruiser View PostThe Champ was modified from column 3-speed to floor 3-speed (no hange in the trans itself), and the stick is in the opening on the side of the trans hump where the 4-speed would have gone, I believe...? May be easiest to find and try a 80 Chevy truck boot at the salvage yard to start. Thanks for the help.
Why not just buy a new one. This may not be the exact one you want but LMC has a great selection of truck parts at good prices. So check out their catalogs for all truck makes.
Bob
It sounds like you just have an ordinary aftermarket "Conversion Kit", side mount floor shifter, any Mr. Gasket or whatever Auto Parts Store shifter boot and retainer will work on that.StudeRich
