Rear End Noise
  • Rear End Noise
    I have a '50 Champ Starlight Coupe. It has a "fully" massaged Cathcart 185 in it (.060 over, cammed duals) and has plenty of power (about 145 hp). I don't need the 4.56 gears here in the flatlands of the Midwest, so I changed over to a set of 3.73 gears. It now performs much better but now I get a rear end "howling" sound that starts at around 55 mph. It quites down (nearly non-audible) at 65 mph. I had a very good shop replace the gearset and replaced all bearings & seals and properly shimmed. Any help on this would be appreciated. Any fluid change suggestions or additives?
    [8D]
    StudeBakerHarv
    StudeBakerHarv
    * 1950 Champion Starlight Coupe (Cathcart Stg 4 Engine).
    * 1971 Avanti II (RQB-1659).
    * 1960 Lark Regal VIII Convertible.
    I'd bring it back to them to re-check before you put too many miles on it. Something in their set-up is off.
    ErnieR
      Thanks for your reply Ernie. Was hoping for more chatter on this but I guess tht there's no need to go any further than back to the shop for a look-see.
      [8D]
      StudeBakerHarv
      StudeBakerHarv
