I have a 60 Hawk which was missing the stock air cleaner when I got it, and I have not been able to source one NOS or used. It presently has one of those speed shop style air cleaners with the two pie plates and the open element sandwiched between them. This works fine, but I hate it because it's noisy (you can plainly hear the air sucking in under open throttle conditions.)
To add to the issues, this car has a Mark IV air conditioner in place, which may be why the stock air cleaner is missing, although I don't see why it wouldn't have fit.
This setup uses the stock WCFB 4 barrel carburetor.
Years ago I would have just gone to a wrecking yard with a tape measure and found some 1960's brand X air cleaner assembly which would fit. But these days, the yards are full of imports and plastic cars from the 1990's.
Has anybody run across an air cleaner assembly which has an enclosed element which works in this application? It looks like an early 60's Buick small block air cleaner might (barely) fit except that those usually had AFB's and I can't remember if the WCFB has the same air horn opening dimension. The car is never going to be totally stock so I'm not worried about using a non-original part on it.
