Only when engaging 1st gear do I get that high pitched whirrring squeal. Not reverse or any other gear.....NORS T-O bearing "assembled in Mexico"........: new complete clutch; bearing, bushing, plate & disc.......Preview of future trouble ? About 200 miles on new set up....
Throw-out bearing noise.....squeal ?
Are you SURE, you have BOTH cases of your Overdrive Transmission (if equipped) completely FULL when level to the fill plug of SAE 85-90 Wt. or equivilant GL-1 Gear Lube?
It sounds like a bearing, shaft or Oil Slinger in the Trans. is without Lube, worn or out of place.Last edited by StudeRich; 01-29-2011, 06:04 PM.StudeRich
