I had the opportunity to remove my manifold from my 51 Champion and while I had access to the valve covers I decided to remove them, clean things up a bit and put on new gaskets. The existing valve covers were attached by two bolts to each cover and each bolt had a locking washer on it.
I purchased a gasket set for the engine and along with the valve cover gaskets came eight copper washers. Four about the size of the bolt head and four that are smaller in diameter, but no instructions. I've been told that the copper washers are to be used instead of the locking ones to prevent oil leaks.
My questions is how to install these? Do I double up on the washers (using one large and one small for each bolt?); and if so, do I place the small or larger washer against the valve cover.
Personally I'm thinking that the washers should be stacked with the larger one against the bolt head and the smaller one against the valve cover, this way when it's compressed I should get a good seal; but this is only my educated guess.
Does anyone know the preferred installation procedure?
Would appreciate the help.
Phil
Phil
