View Full Version : Got emergency brakes?
Flashback
12-16-2010, 01:35 PM
Been a lot on here about disc brakes,and now dual master cylinders are back also. I guess
EVERYONE has emergency brakes, RIGHT ?
Jim B PEI
12-16-2010, 01:40 PM
Yup, and I use it even with modern automatics. Could never understand why some people never used them with autos. Have a friend who never uses one, and so the the PB always seizes up...and explained without success several times how a parking pawl can slip or break.
ozarkman
12-16-2010, 01:46 PM
Nope! Floor is rotted and the front brake cable has no place to mount. It's on the list! Got everything zip tied up so it won't drag.
silverhawk
12-16-2010, 01:55 PM
Yes, I "have" one. I need to get it on one of my dad's lifts and adjust the rear brakes for it actually works.....
N8N
12-16-2010, 02:13 PM
Every car I have the parking brake works. One of those things you insist on when you grew up near Pittsburgh. Oddly the one on my last company car gave me the most trouble of any ('05 Impala) it would go out of adjustment between oil changes. I use the park brake religiously every time I park a car.
jackb
12-16-2010, 02:19 PM
Still don't have a working one in 63' Cruiser w/ discs..Dave T-bow claims the same..
rjohnston79
12-16-2010, 02:58 PM
Mine is not-functional on the '63 Daytona... I assume that handle under the dash should just pull towards me? Or do I need to twist it or something?
showbizkid
12-16-2010, 03:05 PM
Ron, the handle should be horizontal when the e-brake is disengaged. Pull it straight toward you and it will ratchet out to "applied' position. Quarter-turn clockwise and push forward to release.
Michidan
12-16-2010, 03:25 PM
No.
Dang it.
There's a handle on the dash of the ole 52, but it pulls right out. No cables at all. One of those projects that I figured could wait. But I should do something.
Lets turn this thread into tech. Who knows a good setup for modified cars. Maybe even somethig that applies on the driveshaft?
Nelsen Motorsports
12-16-2010, 03:54 PM
I have a Lokar floor setup going to the Right Stuff disc brake kit on my MoPar 8 3/4. The E-brake is cable operated and manually works the rear calipers which are 70s Cadillac units.
Flashback
12-16-2010, 04:47 PM
Sounds like a good idea Michidan . Lets do some tech posts. Alex "you first" sounds like you got one
of intrest there. Maybe we can see some on different years, modified and Original.
52 Ragtop
12-16-2010, 07:49 PM
Also remember, IF you have "my" rear disc brakes, GM recommends that the E-Brake is set when parked. This is to help keep the rear discs adjusted.
Jim
