I fried the electrical components of my overdrive a couple years ago. Its a long story, but trust me, lessons were learned. Anyway, I have been patiently scouring eBay and accumulating parts for the overdrive. I have:
1. Replaced the kickdown switch with a new one
2. Replaced the reverse lockout switch with a new one
3. Rewired the entire car
4. Bought a working, used solenoid
5. Attempted to rebuild (apparently unsuccessfully) the OD relay as a solid state unit, using instructions found on the SDC website.
6. When that didn't work, I bought a used, supposedly NOS (although I doubt it) supposedly 6 volt OD relay that is supposed to be a 6 volt Nash unit. I thought that I understood that Nash OD units were also made by Borg-Warner.
Today, I went out to install this Nash OD relay (it has a stamped logo "RBM Made in USA") on my car. The terminals are different than my old one. Instead of "sol", Ign', etc. they are labeled (Clockwise, starting in upper right) 2, 1, 3 (fuse), L. I worked on the apparently incorrect assumption that the wiring positions were the same as my old one and hooked up ignition wire to #2, solenoid to #1, battery to #3, and kickdown switch to L.
I went out to test it on the car. When I got up to 30 MPH, the ampmeter pegged to charge and the fuse on the relay blew. I slowed down, disengaged the OD, and everything returned to normal.
My questions are these:
1. How can I determine the correct wiring configuration for this relay?
2. How can I test the relay to be sure it works, off of the car?
3. Will this "off brand" relay work with my OD?
4. Could having the case grounding out be a problem? This relay has rubber grommets that I assume are intended to electrically isolate the case from the firewall. The Stude relay has no such insulators.
5. Is there any way, short of buying a new relay for $95+, that I can be sure that the relay really is the (only) problem with this system?
Oh and by the way, I have a used 12 volt Studebaker relay that I stashed away, anticipating that I might use it if/when I switch over to 12 volts. Can it be of any use to me in my current 6 volt configuration?
Advice, enlightenment, even smart-ass remarks, would be appreciated.
