I just bought this M15-20 flat bed and previous owner told me that it was running a year ago. So I got thing running, but no oil pressure. I removed an oil galley plug and oil squirts out when running. I attempted to remove the oil pump but it must be captive by a clip or something inside the engine. I did remove the non-driven pump gear and it looks OK. Hand turned the engine to make sure the driven oil pump gear turned, OK. I mounted a known good gauge on the oil galley, still no oil pressure. I removed the oil relief valve, cleaned it up and re-installed it (PIA). Still no oil pressure. My next thing to try is what you say I should have done in the first place, Replace the oil...
Is it possible that the oil pump pick-up tube is plugged up?
Before you all faint, I never run the engine more than 10-15 seconds and some oil is making it to the bearings...
Thanks,
John
Thanks,
John
