Anything special one has to do to re-pack the rear wheel bearings on a '64 Daytona?
Once the rear drums are pulled via a wheel puller......and the axles pulled.......does one have to use new grease seals etc.........I was told it is an involved process.......using micrometers to set the axles back in..........I had hoped this could be a plug-n-play situation...
Would appreciate as much info as possible before I attempt the 'deed':-)
Thanks in advance for the help.
