We pulled the engine tonight on the '57 Golden Hawk, and removed the transmission and torque converter. I cannot find any identifying numbers on the torque convertor that look anything like the part number in the Chassis Catalog. (someone installed a Ford transmission in the past, but it APPEARS the bell-housing is the original, as the dowels/holes were not disturbed at all, so I am wondering if I also have the original Golden Hawk converter or not?). I was able to buy the 'correct' Flight-o-matic from a fellow SDC member (thanks to this forum!), complete with torque convertor, but that one doesn't have a number either, and has 'remanufactured' stamped on it. They both have a set of numbers stamped in them (similar but not identical to each other) but nothing at all like the part number in the catalog; may just be serial numbers...?
So, how do you identify a torque converter? The '57 Golden Hawk converter was unique (common with the '58 GH and Packard Hawk...?) so obviously I'd like to install the correct one. Thanks!
