Good evening, all. I just had my tank cleaned and sealed, and reinstalled it with all new bolts/nuts.
I'm puzzled at the one bolt/nut/spring combo I removed from the passenger side mount - is
the pictured long bolt surrounded by a (separate) beefy spring and using a castle nut something
used originally? I see something like it in the manual, but the diagram is hard to read..
The only thing I could think of was the they tried to use it to level the tank, tightening the nut against
the spring? If necessary, I can clean those up and reinstall them easily enough.
I'll send some pics later of the POR-15 job in silver for the outside of the tank and filler neck, and in black for the car
frame and trunk floor area- still have to touch up a few areas of it. Grey for the inside of the gas door enclosure, with a new rubber junction on the tank to filler neck and new grommet on the neck inside the filler door enclosure. And a Stude locking gas cap I found on Ebay that I had rekeyed the same as the glove box/trunk key.
Regards,
Clarence in Virginia Beach
Regards,
