Good evening. Got my tank out, and had a radiator shop clean and seal the inside. I will clean and coat the outside with silver-colored POR-15. I already did the POR-15 treatment to the area of the car's underside where the tank will be returning.
I am replacing the very old steel fuel line, and want to ensure I don't run into a problem with how I route the new one.
Is it normal that the fuel line that runs up the driver's side frame rail then takes a route behind the pictured sheet metal cover on the frame, near the back of the wheel well (which is also behind the metal splash guard that covers the dimmer switch)? From there, it goes through a rubber patch and into the engine compartment.
Also, what is the curved item just above the fuel line in the pic, the long flat piece with one hole drilled into it? Is this a moving part (brake pedal?) that will cause interference with the fuel line?
Regards,
Clarence in Virginia Beach
Regards,
