Can anyone direct me to a source for a 12 volt fuel level sender for my gas tank? I also need the rubber boot from the tank to the filler pipe. Any help would be appreciated.
'51 2 door sedan fuel tank issues
Some of the Studebaker vendors including myself and others stock a universal tank sender which would be the best solution. I assume from your post that the car was changed to 12 volts as originally they were 6 volt systems.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
And if you use a 12 volt sender, you will have to get a 12 volt dash unit, too. The sender and dash unit are a matched set, and you have to change both to convert to 12 volts.
If the original six-volt sender is still OK, the simplest way to do it is to buy a "Runtz" voltage reducer for the gas gauge alone. That will provide a regulated six-volt supply to the original gas gauge. Polarity is not an issue with them (gas gauges). You will have to observe polarity with the Runtz itself.
If your old sending unit is bad, you may be able to install the guts from a later 12-volt Stude gauge into the housing for the '52 gauge, and then use a universal 12-volt sender.Gord Richmond, within Weasel range of the Alberta Badlands
Yes I have one I'd sell. I'll send you a private message. Check notifications at top of page.
Originally posted by ckltrk View PostDo you have the 12 volt sender to sell?Frank van Doorn
Omaha, Ne.
