Hawk wheel measurments
  • Hawk wheel measurments
    Has anyone every done a wheel measurment for a 59 thur 1961 hawk. These measurments are outlined in any wheel book, It includes the with of the drum, height of the wheel and how much back space there is on the front and back of the tire to fender area? My fenders are off and I just can't get the right demintions.Anyone with custom wheels would have to have this done before their purchase.
    Studebakers forever!
    This has been touched on over and over in the past year, but I think
    that the dimensions you are asking for is not backspacing, but the
    distance from the tire to the fender? Obviously this depends on the
    tire/wheel package you want. The best thing is to wait until your
    fenders are back on and check with your local LARGE rim seller to get
    this neat tool thats out there. It takes the place of the rim/tire
    and allows you to "try" different wheel backspacing, tire size and rim
    size without unbolting and rebolting it on. Its been mentioned in a
    few car rags recently and there are a cheap and an expensive version.
    Both do the same work. - Tom
    PHP-01201
    Wheel and Tire Fitment Tool, Diameter/Width/Backspace/Bolt Pattern, Each
    Percy's takes the guesswork out of proper wheel fitment!
    These revolutionary new tools allow you to get a perfect fit the first time and every time when selecting new wheels and tires. Percy's WheelRites eliminate returns and delays due to an improperly specified wheel. These tools bolt onto your vehicle's hub to precisely simulate bolt pattern, wheel diameter, wheel width, backspacing, and tire profile. The WheelRites allow you to simulate a number of different sized wheels and tires without the expense or hassle of having multiple sizes of wheels and tires on hand.
