View Full Version : Studebaker Power Steering Hoses Replace - how to
sbca96
04-22-2007, 01:54 AM
EDIT for picture location, and to add critical Q & A thread link.
http://forum.studebakerdriversclub.com/topic.asp?TOPIC_ID=7602
The above link covers changes to the bends that were REQUIRED to use
the SI hoses. As delivered the hose would NOT allow the wheels to be
turned both direction. A tubing bender was required, along with a
vice and some choice sware words.;) 12/31/08
Now back to the original thread:
This is something I am NOT looking forward too. Talk about messy. We
had a '63 Wagonaire that needed hose replacement, I did that one too.
That was [u]many</u> years ago, I was a bit more flexible .......[B)]
I thought it was worthwhile to document as best I could how the hoses
are routed from the factory. I took a bunch of pictures and thats how
I will start this thread - by just posting them in the first entry.
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_001a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_002a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_003a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_004a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_005a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_006a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_007a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_008a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_009a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_010a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_old_011a.jpg
Tom
DEEPNHOCK
04-22-2007, 08:26 AM
Good on ya' for taking before pic's.
That will definitely help you when it comes to reassembly.
04-22-2007, 08:27 AM
Tom,
Thanks for posting the great pictures. Power steering hoses are often routed badly, on Avanti's.
The hoses to the ram, from the control valve, are well shown in the illustration from the parts book, and pictures Stan Gundry posted:
http://www.studebaker-info.org/tech/Diagrams/PS2.JPG .
http://talkshop.blogs.com/photos/photos/index.html .
However, the parts book shows only an early version of the hoses to the pump. The metal portion of these early hoses goes straight forward on the control valve. They route up, to the rear of the steering box.
The metal portion of later pump hoses, like the ones on your car, curves to the rear, like the hoses to the ram. I don't think Stude made a drawing that shows routing of these later hoses.
My pictures of the hoses on the control valve are in the photos at the Yahoo Avanti site, or at:
http://www.studebaker-info.org/tech/psteer/valvehose.html . Identification is clearer with a little more punctuation, or if each hose is explained on a separate line. I think I was done in by "wrapping"!
#1: Yellow, Ram, Bottom, Right Turn.
#2: Green, Ram, Top, Left Turn.
#3: Blue, Pump, Pressure.
#4: Red, Pump, Return.
Your excellent pictures show the clamp on the pump hoses that's on the fender apron of later cars. On these, the pump hoses route around the front of the power steering box, and up the apron. I posted a picture of the hoses on Paul Johnson's '64 Avanti, in "Files", at the Yahoo site. Contrast under the hood is better, because of the color of the car.
I'm supprised to see the clamps nearest the control valve on your car. Do you think they are original? I have only one clamp at that spot; and it's used for the fuel lines. The rubber portion of my pump hoses curve up and forward, above the control valve. Then, they go around the front of the steering box, and up the apron, to the only clamp. The unrestricted length gives more flexibility; and doesn't leave them loose enough to hang down, or get into trouble.
The hoses to the ram on my car have no clamp at the control valve either. The first one is as shown in the parts book; and there is a second further forward.
My car is a '64. Neither power steering hoses or fuel lines were original when I bought it. I "rediscovered" the hole for the clamp in my fender apron when I replaced the hoses. I certainly can't guarantee I've routed them, or positioned them on the control valve, the way the factory did. Maybe I have. All the clamps and mounting screws in the late parts book are accounted for; and the hoses fit pretty well.
Mike M.
N8N
04-22-2007, 09:29 AM
All I have to say is "me three" - I wish more people would document original routing of hoses, lines etc. for those of us who inherit "not quite factory" cars :)
(still wouldn't mind having a set of same for a '55 coupe with power steering)
sbca96
04-22-2007, 02:41 PM
I believe they are original, this car "only" has 100k on it, though
it was 'restored' in the 80's. I dont know to what degree that means,
and I have no clue what they did. After going through the car, I bet
it was only interior and paint. Mechanically the car is in OK shape,
but not rebuilt-in-the-80's shape. Since the 'restoration' the car
has received MAYBE 600-1000 miles. Maybe others will confirm the two
clamp setup, but the routing seems to work pretty good. Do you think
that its an improvement?
Tom
studeclunker
04-22-2007, 04:51 PM
The manual recommends pulling the motor to do this. I have to concurr. Getting to the lines to tighten them is a bugger when the motor is in place. If it is taken loose and raised about a foot (getting everything out of the way), the problem is solved. I had to pull the motor in my '63 wagon and that's when I replaced the hoses. The routing of the hoses is CRITICAL! I found this out when the exhaust manifold burnt through my return hose.
http://i16.photobucket.com/albums/b18/Studeclunker/december%2006/HPIM0234.jpg http://i16.photobucket.com/albums/b18/Studeclunker/56%20Parkview%20Wagon/56wagonleftfrontclipped-1.jpg
Home of the famous Mr. Ed!
Lotsa Larks!
Ron Smith
sbca96
04-22-2007, 05:08 PM
Yes, I have been told the best way (other then pulling the engine) is
to remove the pitman arm with the control valve and the hoses still
attached. Then, clean, put in a vice remove the hoses, reinstalling
the new ones the same way, and snaking the hoses back where they were.
The next step after taking the above pictures is to test this theory
and see if it can be done. Looks possible. I need a larger pickle
fork for the pitman arm though. I bought a threaded tierod puller, it
is supposed to also pull pitman arms, but I dont know if it has the
reach. Hopefully all will go well.
Tom
04-22-2007, 05:18 PM
If the routing works pretty good, that's a strong argument in its favor! My interest in how the factory did it, is as much in finding a good way to do it, as for the sake of originality. Make sure the hoses don't kink or pull too tightly through the full range of control valve movement.
I think your clamps are examples of the original Stude "clip, 1543994". I found only three listed for the whole car in the Dec. '63 parts book. Two are in the power cylinder and control valve section. They are secured to the frame with two self tapping 1/4" screws. I think these are the two used separately on the hoses to the ram, further forward than the pair in your picture.
A third clip, with the same #, is listed with the pump parts. It's held to the fender apron by a 5/8" long 1/4 20 screw, nut, and washer. I think the fact that it's a through hole, without a nut plate in the fiberglass like the horn relay and regulator, indicates it was an after thought or revision. Early cars, with the other type pump hose, ran the hose beside the exhaust manifold; and wouldn't have used it.
Since your car is a '63, it may have had the earlier type hose originally. Is the retainer spring or its bracket still in place on the steering box, like in the drawing I listed above? Maybe the later style hoses were installed in the '80's, with the double clamps as an innovation.
I took a quick look at mine. The clamp on my fuel lines in that area is retained by a bolt through the flange at the edge of the frame; not the center of the bottom plate. Oddly enough, I used two "Adel" clamps held by one bolt, like your PS clamps, to hold the fuel feed and return lines. I don't know what the original arrangement there was.
Mike M.
04-22-2007, 06:56 PM
I recommend removing and installing the control valve and pitman arm assembly with the hoses attached. That's how I did my Avanti.
The pitman arm puller I used looks exactly like the one Summit Racing sells for $14.95, WMR-W142 @ :
http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&Ntt=Pitman+Arm+Puller&searchinresults=false&N=+115 .
I replaced the puller's bolt with a short, 1/2" fine thread hex bolt, reversed, so the head bears against the end of the steering box shaft. I have two bolts in the box with the puller, 1 1/2" & 2" long, threaded all the way up. I'm not sure which worked. The shaft isn't tapered; and I remember the arm came off easily. There is a mark on the arm and shaft, so you can put it back in the same position.
It's a good time to replace the seal on the steering box shaft.
The tie rod end on the reach rod came loose with a pickle fork. It's easier to get to than the one for the ram, which I unscrewed, like you did.
Total length of the reach rod and control valve is specified in the manual. It has to be right, as well as the pitman arm position on the shaft, to center the steering worm. The worm is wound to give progressively faster steering, away from center, when the wheels are pointed straight ahead. The lengths of the two tie rods should be the same, too.
On the control valve, there are soft aluminum seats in the valve housing that the flared hose ends seat against. These are often pretty beat up. One really should come out, to clean a check valve behind it. These may be a standard hardware item. Does anyone know where to get them? I left mine as they were, and hoped for the best with the check valve; but it would be nice to know where to get them.
Mike M.
sbca96
04-22-2007, 07:32 PM
Dammit .. the one I just bought was like WMR-W80557. Think it might
work? So the pitman arm is marked, I seem to remember that, but is it
also missing one "groove" so that it only goes on one way? For some
reason I seem to remember this being the case on my '60 Hawk. No?
Also, did you find you needed to remove the started to get enough room
to work on the pitman arm? Looks like it might help. I just do not
want to remove anything more then I have too - after seeing the damage
someone did to the Ram pivot bolt threads. My guess is it was put on
with an impact gun. The bushing looks to be in TOO good of shape. So
you might be right that the hoses and such were changed in the 80's.
Tom
04-22-2007, 08:03 PM
The puller I used was definitely like Summit's WMR-W142. I just checked "opening" and "pull travel". I don't know what they mean by "3/8 inch drive", though. It isn't.
The other one is only a little smaller. Maybe it will work. You will need to use a shorter, reversed, center screw.
I did have the starter off.
I think if the seal has been leaking badly enough, you might not need a puller!
I don't remember if there is a groove missing on the pitman arm, so it will only go on one way. There was a mark. You should make one if you don't see it.
Mike M.
sbca96
04-22-2007, 09:52 PM
I wish .. thats not MY kind of luck though. Actually I dont see any
leakage from the steering box. I bought the seal, but I am tempted to
NOT change it. I hate disturbing things that are OK. But as you and
I BOTH know, if I leave it .... THEN it will start leaking.[xx(]
Tom
Lenny R2
04-22-2007, 11:11 PM
Tom
I just finished changing my P.S. hoses on my 64 Avanti R2.I removed
the starter and took the exhaust pipe loose.It was a struggle but you
can remove & replace the hoses with the control valve on the car.I
hope i never have to change them again.I had to grind a few line wrenchs
down to fit.
Lenny
bige
12-31-2008, 10:42 PM
I've done mine twice on the car. If you're replacing them just cut the tubing and use a socket to remove the nuts. There are replacement hoses that are bent wrong and I had to buy a second set from a different vendor to get hoses that worked.
ErnieR
http://i146.photobucket.com/albums/r241/AvantiR2/track.jpg
On its way to a 15.097 Spring 2006.
sbca96
12-31-2008, 11:06 PM
Thats covered on the link I just added to the top, yes the hoses had
been bent incorrectly, here is the incorrect bend and rebend :
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose012a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose013a.jpg
Tom
53k
01-01-2009, 02:46 PM
When I replaced all four hoses on my '64 Wagonaire a couple years ago, I did it with the engine in and the pitman arm on. Like everyone has said, it's not easy, but I went out and bought a set of stubby end wrenches and was successful in tightening the hoses to the control valve with them. I ordered my hoses from Jon Myer and, while they were a little different from the originals, I didn't have any problem with the bends.
Paul Johnson, Wild and Wonderful West Virginia
Museum R-4 engine
1962 Gravely Model L (Studebaker-Packard serial plate)
1972 Gravely Model 430 (Studebaker name plate, Studebaker Onan engine)
WCP
01-01-2009, 09:10 PM
In reviewing Mikes photos on yahoo, I agree with the hose arrangement at the control valve, with the exception that the pressure hose (blue) is rotated to pass upward and tuck into the groove of the control valve where it comes together with the return hose toward the rear of the valve. Those hoses then loop forward around the front of the steering box and up and rearward to a clamp on the apron. The hoses then loop forward against the apron projection and under the regulator terminals, wrapping forward to the pump. I add an extra clamp at the inner regulator fastener to restrain the hoses from chafing on the left emission shield. There should be only one clamp on the frame opposite the valve and the one forward near the ram. The hoses should form a neat bundle toward the rear of the valve. There should be no hose crossovers necessary. I've never had to perform major rebending of hose ends - just some minor tweaking to "bundle" the hoses. My current Avanti is an early one (R1236) and has the spring clip mounted toward the rear upper steering box cover capscrew and no hole in the apron for the clamp as I recall. I think the hoses originally came around the steering box and were restrained by a spring as used on the Hawks and clipped to the steering box, and then would have followed the same path as I'm currently using. When I'm happy with the fit of the hoses, I add a hose clamp at the forward steering box to frame mounting bolt to minimze any chafing at that point by locking the hoses to the steering box. Do a full lock to lock check of the steering to check for any interference. Make sure on a full right turn that the pitman arm is not stiking the steel tubing of the turn hose. If it does, loosen the valve to reach rod clamp and rotate the valve a few degrees to give the necessary clearance. It's not enough to alter the steering geometry. Hope this helps. Some day I'll get set up to post pictures.
sbca96
05-30-2014, 03:10 AM
Getting back to this on how I got from point A to point Z ...
Also, I took some pictures of the new hoses. You can see the original hose on the control valve
(brownish/gold), and I am holding the new hose, the bend is completely different:
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose002a.jpg
Also notice that there is NO way the return line will clear the tower I broke off ... whats going on
here??
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose001a.jpg
According to the packaging I got the correct hose ...... BTW, is this new hose "made in USA" or
"made in Canada"?
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose003a.jpg
I bought a tubing bender and mounted it into a vice at work. I put the handle in the vice, I then
could use my body weight and hold the tube. I made a bend the opposite direction, and it seems
to clear now :
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose004a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_ControlValve/ControlValve_042a.jpg
I got the control valve back on the car, I routed the hoses the way they were originally and one
of the power ram hoses is not as long as the other!!!!!
This is the funky long bent one that replaced that quick bend one on the valve before :
I think I will have to remove this and rebend it so its a quicker bend which will in effect make the
hose longer. I think that I would have had better luck having the hoses made locally, this is REALLY
starting to piss me off now.
Here they are :
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_ControlValve/ControlValve_038a.jpg
On the car :
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_new_001a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_new_002a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_new_003a.jpg
Tom
sbca96
05-30-2014, 03:12 AM
OK .. I spent HOURS there routing and re-routing hoses. First I put the power ram back on the
car to get a reference of where the ends of the two steering pressure hoses should be. So, my
conclusion is that the one hose IS too short, I would say about 6 inches too short. With the all
hoses clamped down like they were, I can ONLY turn the wheels until it is straight ahead. At that
point the hoses pinch and hit the exhaust. The "short" hose is fully stretched, and I see no way
to route it that would give me enough room. My solution is to remove the hose from the car and
bring it to a local shop that makes pressure hoses. I will have them cut the hose in the center
(between the two mounting clamps) and add a 6 inch length of tubing. I also noticed that the
ends are NOT crimped on correctly, causing the hoses to be twisted to get them to line up on the
car. I am very disappointed with this.
Here are the pictures ..
Wheels barely able to be pointed straight ahead :
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose005a.jpg
Notice a VERY stretched pressure hose at the halfway point??
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose006a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose007a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose008a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose009a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose010a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_problems/ControlValveHose011a.jpg
Tom
sbca96
05-30-2014, 03:16 AM
I am stumped. I took the hose off tonight after work, and pulled the old one out of the bag. Side
by side they are the same length. Seems that the new hose SHOULD be longer since it now goes on
the opposite side then it did originally. I dont get it. I guess I can wait on getting it lengthened,
and rebend the end to match the old hose, then I can mount it on the "correct" side, and the longer
metal end will give me a little more length - maybe I wont want it then? I could do a rebend just to
allow me to put it back on the "correct" side. Here is the picture I took of old vs new :
Alright ... if it doesnt work ... redesign it ...
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_new_004a.jpg
Done. The hoses are on, everything clears, rebending the end gave me about 3 inches of extra length,
and bringing it out on the CORRECT side of the control valve eliminates the problem of catching on the
back of the control valve. I will post the modification pictures on a future thread. I just want this thing
drivable again. Studebaker obviously did this a certain way originally, why S.I. decided to change it is
beyond me.
Tom
sbca96
05-30-2014, 08:16 AM
A different angle of the hoses was requested :
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_new_007a.jpg
http://emperorjordan.com/sbca96/images/Avantinewimages/Avanti_Power_Steering/PS_Hoses/PowerSteeringHoses_new_008a.jpg
Tom
