hi again, standing out in the shop contemplating the '57 Golden Hawk project. The only other car I've restored is a 1930 Model-Ford coupe. A little bit smaller and less intimidating, and easier to 'bite-size' each part of the car regardless of how you break it up.
With this full-size beast, I'm looking for suggestions on what has worked well for you experienced Stude folks. I plan to do the body work myself, up through final-color anyway, at which point I'd bring the body piece-meal to a paint shop. (fenders, trunk, hood, doors loose, with remaining body on a trailer).
The chassis, I've not decided for sure if I'll COMPLETELY disassemble the differential and Flightomatic transmission (supposedly <64,000 original miles) and remove springs, etc.. etc.. or not. If so, probably would sand-blast it and prime. If not, wire-brush and POR15 chassis black...
And probably leave engine until last, just because it is the most fun (for me, I HATE the body work!) and gives me something to look forward to. Anyway, here is my first-blush sequence:
Remove seats, (done), and interior panels
Remove wheels/drums (done)
Remove gas-tank
Remove hood
Remove engine, radiator, headlights...
Remove all stainless (and chrome) trim (how do you DO that, by the way?? Pry it off and pull the little clips out with it? Or should you nip the clips from the back side where possible to avoid bending the stainless trim pieces???)
Remove windows/glass/windshield
Remove steering column and power steering (might have to do this prior to engine...)
Remove doors
Remove front fenders
Remove deck-lid
Remove tail fins and white 'facade' piece on fins
Remove body from chassis (I have an "H-frame" that connects to my cherry-picker)
Chassis work here? OR
Have body, fenders, doors, etc... media-blasted (hoping to find someone who comes to my place with portable unit)
With all sheet metal blasted, photograph and/or mark areas to be cut out.
Prime everything with two-part epoxy primer immediately.
At this point, order the new sheet-metal panels (I'll for sure need front-floor pans, rockers, and the rear-end of each front fender)
Cut out rusted sheet-metal and weld in the panels, re-prime of course...
Body work and paint
Perhaps in parallel (depending on season, winter in Minnesota is not a good time to do body work) do the chassis disassembly, clean-up & painting, rebuild the brakes, and maybe the engine (how does it work to have the engine all assembled BEFORE putting the body back together? That was how the factory did it, so must work OK, right?).
Reassemble the now-painted the body, fenders, doors.... with fresh rubber and seals...
Finally, put the trim and glass back on, and lastly the interior.
Question, how about the wiring? Get it all done BEFORE putting the body back on, and then connect to dashboard as final terminations only?
Sorry for the long rambling post, interested in suggestions on what has worked well for you in similar situations. Thanks!
Remove gas-tank
Remove hood
Remove doors
Remove deck-lid
Body work and paint
