getting ready to order new rear leaf springs from eaton.
$479 for a 60 lark. emailed them and it's $400 to re-arch a set, with no guarantees it will take it correctly or how long it will last, so it's just as well getting a brand new one. Eaton also can give lift of up to 3 inches if desired.
My question is, has anyone installed new rear leaf springs into a 59-63 lark, and if so, did you just go stock or raise it a bit? Seems like the lark would benefit from an inch or so above stock to give it a better stance.
also saw a thread on composite springs from "flex-a-form". Seemed to be a positive response. Still the case?
Or is there a better place to get them? (new - not from parts cars)
Thoughts, comments?
EDIT:
I got a response from Dave Thibeault. He has new lark 6-leaf heavy duty leaf springs which he says will work fine and help stance, and at $190 each. Sounds like an okay deal.
Thoughts, comments?
EDIT:
