View Full Version : U Joints and center bearing
jays48
04-20-2007, 10:53 AM
Somewhere in turning wheels I read that Studebaker used Spicer U joints and they were still available because the same joint is used in modern hi-los and some John Deere equipment. The bearing (yoke) assembly is listed as Part # S16059. could this be a Spicer #?
Stude4x4
04-20-2007, 11:23 AM
Spicer U-Joints are readily available. What application are you needing a U-joint? Studebaker used a common size U-joints for the most part. The yoke size on Dana 44s are 1310, which is very common. That part # you listed is not a spicer number. Here is a link to Spicers website. http://www2.dana.com/expertforms/demenu.aspx?prod=JOI
Jake
-Home of John Studebaker-
http://s158.photobucket.com/albums/t95/stude4x4/
http://varozza4x4.com
http://s158.photobucket.com/albums/t95/stude4x4/th_505911685npTTka_fs.jpghttp://s158.photobucket.com/albums/t95/stude4x4/th_FullSize.jpghttp://s158.photobucket.com/albums/t95/stude4x4/th_normal_scan.jpg
jays48
04-20-2007, 04:26 PM
Thanks, I learned today at Auto Value that the joints are readily available. Precision #369 is the one and they had them in stock
