We've got about 300 miles on our freshly rebuilt 1964 259 V8. It's time for a head re-torquing. We used the thin head gaskets on the rebuild.
BUT WAIT ! Why do we have anti-freeze puddling at the back of the block in the ledges next to the distributor? The water pump to block and head joints are dry, as well as the dummy plates at back of heads, and the thermostat housing area. No seepage at temperature sender either. But what we do see is seepage from all along where heads meet block, on both sides of engine. So I re-checked the initial torque, and it still seems to be the same 60lbs as originally set.
So, here are the questions:
1. Do the shim style head gaskets require more torque than the 55-65 lbs recommended by the shop manual?
2. Is it not unusual to find some coolant seepage before the obligatory re-torque of the heads?
3. I initially torqued to 60 psi, should i go to 65 with my re-torque?
4. Any other words of wisdom?
Thanks,
-Larry
Thanks,
-Larry
