Got a lot accomplished over the past week or so I've been home, and particularly this weekend. Winter is coming, and I've been trying to get the yard in shape, mowing, weed-whacking, and trimming hedges a little bit. Needless to say, the mowing necessitates moving the vehicles so I can mow under them. So far, the move-ees include: '64 Avanti, '64 Wagonaire, '64 Daytona, '52 2R15, the Studebuggy, '63 Lark VI, '53 2R17A, '62 Champ, '47 M16, and a Cacavalier, which has been tentatively sold down the road. All these moved under their own power, and four of them were moved today, the largest per-day migration of this season.
The M16 also is in the throes of getting a little work done on it. I fixed the loose exhaust flange, and put a gasket in it, and I began re-installing some of the sheet metal for the front clip that I took off and painted a couple of years ago. I'll do some more tomorrow, and hope to have everything, except for the front fenders, back on it.
Yesterday, I spent literally hours making a tire leak-check basin out of a segment cut from an old tractor tire, and some scrap metal for its support stand. I had a brilliant idea that turned out to be less than brilliant. I figured when I cut the tire, I'd leave a little of the wire bead hanging out, and weld the support frame to those stubs. Well, I couldn't weld to that stuff to save my life. Tried the stick welder, and tried the acetylene torch with some brazing rod. No stickum at all. So I cut the stubs off, and trapped the bead behind pieces of angle iron instead. The finished product is ugly as all get-out, but it will serve its purpose.
And I have enough tractor tire left to make at least one more basin. Might be good for an electrolytic deruster. I cut the bead wire with a cutting disc on the angle grinder, and a reciprocating saw cut the rest of tire pretty well.
The tire test basin will get put to good use during the next few days, I'm sure.
