For my 62 Lark Chevy V8 conversion, I'm going to keep it as stock looking as possible. I'd like to use at least a 2" dual exhaust, and was wondering what diameter the factory dual exhaust pipes were. The only ones I'm really concerned with are the over the axle pipes and tail pipes. I searched the forum but couldn't find any posts dealing with this. I like the look of the stock pipe, so i'd like to get the same thing in a larger diameter. Thanks.
Lark V8 Exhaust Pipe Size
Call Don Simmons, he will make you stock looking pipes in several larger than stock diameters. He likely can sell you head pipes for your Ch*vy motor as well, as they were used in 1965-66 from the factory (assuming you are using the rams horn style manifolds)
good luck
nate--
