View Full Version : rewire a 52 champion
beatnic
04-16-2007, 10:33 PM
how hard would it be to rewire a 52 champion?, can you buy replacement harness?, what do you think it would cost at a shop to have it done?
terrymb
04-16-2007, 10:56 PM
Just started rewiring my 52 Commander yesterday. I bought the wiring harnesses from Studebaker International for a cost of $314. These are the front, rear, overdrive, and front turn signals. They come with the correct color codes and connectors. This is plastic, not cloth covered wire. I've only rewired the rear so far, but it went well. After seeing the old wiring, I can't believe the tail lights worked at all.
Terry
1952 Commander Starlight
whacker
04-16-2007, 11:53 PM
I rewired my 51 a couple of years ago. Took about 6 - 8 hours altogether as I remember it. Unless you are an originality nut, use the plastic insulated wire. The trick is to rewire from the hole through the firewall foward, then from the hole through the firewall to the dash. All the dash gauges will come out forward (at least on the 51), and you can wire them while you sit up in the seat. It is not a hard job, especially if you get the harness with the labels printed on the wires. Also print out the wire schematic from the shop manual to refer to when you have questions. Do it yourself, you don't need a shop! Good luck!
rockne10
04-17-2007, 09:32 PM
New wire harnesses are available from a number of Stude Vendors, as well as most harness specialists (expect to pay more).
If authenticity (lacquer coated braided cloth) excites you, expect to be excited to the tune of $750. YnZ's makes a beautiful new braided wire harness.
Then there's the labor of installing. Do it yourself (it's a satisfying experience) or pay someone $300-$500.
Any good shop could rewire it but you won't be happy with the appearence and can pay at least twice what's already estimated here.
Brad Johnson
http://i57.photobucket.com/albums/g233/rockne10/51x2.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight
John Kirchhoff
04-18-2007, 10:54 AM
Maybe I'm crazy, but I plan on making my own wiring harness for my '51. I figure I'll remove the old one, stretch it out on a sheet of plywood, drive two rows of nails for the main harness to lay between and then use nails to locate the wires branching off. Small finish nails or staples will be used to secure the ends in place and I'll identify on the board what they connect to. Then I'll start stringing out new wire of different colors, crimp and solder new connectors, use shrink tubing where needed and identify the color of wire next to the item it connected to. When that's all done, I'll tightly secure the bundles of wires with either zip ties or small hose clamps and start wrapping with black tape. Since I plan on converting to 12V and add AC, a good alternator and a buss ternimal or two, I will need to add additional wires and heavier wires where needed. That way, when it's all said and done, I won't have extra wires hanging around outside of the main harness. I'm sure there's folks out there that have done such stuff before, so am I missing something?
gordr
04-18-2007, 01:52 PM
John, that doesn't sound crazy to me. I think that's basically the way that the OEM harnesses were assembled on a jig. I was thinking of doing the same thing for a project of mine. I bought a roll of tubular gauze bandage from the drugstore, and figure I can slip the wire bundles through it, with multiple layers of gauze, and then spray-paint the gauze black to simulate the original braided jacket.
Is there a scrapyard anywhere near you where they part out old transit buses? You can get lots of nice, un-weathered cloth/rubber insulated wire from interior harnesses in old coaches.
beatnic
04-21-2007, 09:11 PM
would you have to tear out all the interior to do this job? the car is complete but the headlights/tail lights are not working, it has been patched together
studeclunker
04-21-2007, 09:51 PM
I haven't heard of a Beatnick for many a year. Welcome to the forum.
No, you don't have to tear the interior apart. the wires for the rear can go under the car, or along the molding along the door-sills. It's not difficult, just time consuming. Whilst you have the wiring apart, you can convert to twelve volt, if it hasn't already been done.
Be cool, dude. It's easy, man.
http://i16.photobucket.com/albums/b18/Studeclunker/december%2006/HPIM0234.jpg http://i16.photobucket.com/albums/b18/Studeclunker/56%20Parkview%20Wagon/56wagonleftfrontclipped-1.jpg
Home of the famous Mr. Ed!
Lotsa Larks!
Ron Smith
rockne10
04-21-2007, 10:36 PM
Spelling Beatnic with a k just makes me "HOWL". I can't wait to help Beatnic get his '52 "ON THE ROAD".
Maynard G. Krebs probably road in a Studebaker. If it was a '52, the rear harness did run along the frame, not under the carpet. The dome light harness would have run through the pillars and above the headliner.
My earlier estimate of the cost of a braided harness was a couple years old. Today I priced them and they run from $850 to $985.[:0]
Brad Johnson
beatnic
04-22-2007, 04:04 PM
it has been converted to a 12 volt...
the speedometer is working... would i just unplug the gauges and plug them into the new wire under the dash?
studeclunker
04-22-2007, 04:41 PM
Beg pardon? Beatnic is the proper spelling (if proper could be applied to such a person)? Sorry, my Mum always spelled it with a 'k'. So did I. My sister's boy friends didn't mind. So, I always thought it was Beatnick.[:I][:o)] Hopefully, Brad, you were howling in laughter, not anger.
quote:would i just unplug the gauges and plug them into the new wire under the dash?
Yes, exactly. When I did my Lark wagonaire, I didn't remove the original harness till each section was finished. I cut the original harness where it goes through the firewall and passed the engine compartment and lighting harness through, then I started swapping the wires new for old. I don't envy you as on my '52 the wires aren't as varied as on my Lark. This would make it more difficult. The trade off is, as has been previously mentioned, you may be able to just drop the instruments out of the dash toward you. Much easier than a Lark, let me tell you! Just take your time. Remember, these cars were assembled in such a way that each of these items had to be hooked up in a very short time. Therefore it has to be rather simple by nature.
Don't rush, take your time, and you will find it's not that difficult. It just looks daunting.
Oh! as to the dome light, attach a stout string to the end of it (or even a wire) and pull the old wire out. This threads the other in the old path. Attach the new wire (tie or twist) onto the thredding string or wire and just pull it through. Electricians like my father would have called this 'pulling wire'.
Lotsa Larks!
Ron Smith
rockne10
04-22-2007, 09:32 PM
Howl is a poem by poet Allen Ginsberg. It is considered to be one of the principal works of the Beat Generation along with Jack Kerouac's On the Road. Just a little subterranean humor.[}:)]
vegas paul
04-22-2007, 09:40 PM
We're mixing Kerouac, Ginsberg and Maynard G. Krebs all in the same thread? Wow! Add Ferlinghetti and the Electric Kool-Aid Acid Test and it's no wonder Studebakers still live! I knew I would find lots of incredible info on this forum.
Las Vegas, NV
http://i151.photobucket.com/albums/s144/vegas_paul/graciestude.jpghttp://i151.photobucket.com/albums/s144/vegas_paul/1462673_2_350.jpg
Swifster
04-22-2007, 10:16 PM
John, many places like Ron Francis, American Auto Wire, etc., sell complete harness kits in varying styles. I won't say your crazy, but you may have too much time on your hands (j/k). Most of these are modular in nature and car be as basic as you'd want with the ability to add additional circuits. I've made a harness for a race car and this beats doing that by a country mile. Just my opinion.
Tom - Valrico, FL
1964 Studebaker Daytona
http://i74.photobucket.com/albums/i280/Swifster/1965_Studebaker_Commander_front198x.jpg
beatnic
04-22-2007, 10:17 PM
Oh this is great!!!
rockne10
04-22-2007, 11:26 PM
Kevin Bacon never knew you could link Ferlinghetti to Studebaker in one step.[:0]:D
Swifster
04-22-2007, 11:44 PM
:D
Hey Beatnic, you can get one of those harnesses for your car too if you don't care about originality. To have a shop install a harness of any type, you're looking at shop labor rate times the amount of time it takes them to install it (as they milk you for extra time). Harnesses rarely fall under the flat rate system. Start at $75 an hour and go from there.
The aftermarket harnesses have some very detail instructions on how to install them. Just from seeing the underside of my Stude dash, get the I/P harness so that it will be easier to service. I'm setting my dash up so that I'll have just one plug and the speedo cable to unplug to pull the guages.
Tom - Valrico, FL
04-23-2007, 01:00 PM
I earned MANY a paycheck for my efforts of fabricating and installing wiring harnesses in aircraft. Primarily, old F-84s and new Hiller Helicopters. Of course, unlike cars, the process started with the imprinting of wire numbers on specific gage wire - aircraft typically use mostly the same color (white primarily) wire. VERY labor intensive tasks!
Then we had layout boards like John speaks of. Each leg of the harness made to pattern and then the required terminals or connector plugs soldered, crimped or swedged in place. THEN the application of wrappings and/or sleeving to protect the wires from abrasion, weather, heat/cold and various fluids that leak about.
If you DO your own harness, make sure to check continuity per whatever schematic diagram you assemble from. It's alot easier to fix a goof on the bench than in the vehicle!
I've used a couple of harnesses from Studebakers West and liked the results and the quality AND the price.
OH..... and since the car in question's been converted to 12 volts, you can get away with lighter gage wire for your harness. 6volt harnesses deal with higher amperage (not voltage), so the wire has to be bigger to accomodate that current.;) Part of the reason the industry went to 12volts was to save on copper![:0]
Miscreant adrift in
the BerStuda Triangle
