I'm just now getting to assembling the under-hood and under-carriage stuff now that the 289/OD is back in the 63' Cruiser. I still smell mice...(warm) ! Anyway, it seems I bent the OD pad/arm on the throttle shaft upon re-entry into the engine bay.....I need to know the approx. distance from the OD plunger switch end to the center of the throttle pad. I have the adj. screw per the shop manual. If anyone has a spare throttle shaft...I need the little pivot that connect the gas pedal shaft to the throttle shaft.....and I need the larger pivot that goes to the adj. rod for the clutch. This larger pivot also is used for late auto tranny shift lever adjustment................
