I am trying to find rear (outer) bearings and seals for a 64 R3 I'm currently restoring. SI is out and local bearing company can't cross reference the numbers. I did manage to find Twin Traction clutches.
Flanged rear Axle
Flanged rear Axle
Bez Auto Alchemy
"Don't believe every internet quote" Abe LincolnTags: None
Have you tryed this place? They have had every Studebaker bearing I have needed. http://www.alliedbearings.com/
Don't the R3 flanged axles use the sealed '56 Packard Senior bearings? If that is true, Packard Parts suppliers should have some.StudeRich
If it is a true R3 flanged axle, try a forum search. I posted that info about a year back. They are available from a flaps. The kit is the same as a 1/2 ton Ford pickup of the '60's and early 70's, I think. Comes with seal, bearing and wedding band. I had to replace the right rear bearing on R3 5642. E-mail me if you can't find the post and I'll look up the kit number.
Kit part number - CR 88128-R
Thanks for the number.....couldn't find the thread.
Had one guy I know searching online and found some for $600 each. I said Ha Ha Ha.......no!Bez Auto Alchemy
Thanks for the number.....Ordered BRG 88128-R from NAPA 37.50 ea 77 Ford PU. (Also fits Mosier axles for certain 9" rears)Bez Auto Alchemy
