I just bought a 1962 Hawk. I need a radiator. Is there a replacement to be had? I don't think the old one can be repaired. I droped it off in the Shop today and it did not look good!
Radiator
Leroy, check out these two threads:
http://forum.studebakerdriversclub.c...g!!-Dan-giblin...Proud NON-CASO
Romans 15:13
Deuteronomy 31:6
Proverbs 28:1
Illegitimi non carborundum
I may be in the minority here but, the only Studebaker radiators I've seen that can't be repaired are ones that have been involved in collisions.Brad Johnson,
'56 Sky Hawk in process
Originally posted by rockne10 View PostI may be in the minority here but, the only Studebaker radiators I've seen that can't be repaired are ones that have been involved in collisions.1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
Originally posted by Leroy Cook View PostWhat I was asking is there a Radiator out there that will interchange with a 62 Hawk radiator. I have found no direct replacement with other web sites.1964 GT Hawk
PSMCDR 2014
PSMCDR 2013
Victoria, Canada
To answer your question.
There are no direct 'bolt in replacement' radiators sold in the aftermarket (ie: Pep Boys, AutoZone, etc)
You will need to have your radiator repaired, recored, or replaced.
(replaced with another used, reconditioned, or custom fabricated radiator)
The radiator for a 1957 through 1964 Hawk should bolt right in.
(Someone else might have more specific Hawk swap info)
HTIH
Originally posted by Leroy Cook View PostWhat I was asking is there a Radiator out there that will interchange with a 62 Hawk radiator. I have found no direct replacement with other web sites.HTIH (Hope The Info Helps)
Several years ago when my Avanti was being rebuilt, I looked into having an aluminum radiator fabricated for the car. I did a web search and found a custom builder who said if I provided the dimensions he could build one for about $400...a bit more it required transmission cooler lines installed. It ended up I didn't need it as my radiator was in fine shape and didn't require anything but a good cleaning out.
Unfortunately I don't have the custom radiator shop's name but I believe they were in Ohio.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
