My car has been starting hard lately. Yesterday I pulled the top off the carb, and the float bowl was nearly dry. Gas is not leaking outside the carb, but seems to be leaking through the carb into the intake manifold. What should i be looking for?
1954 232 V-8 WW carb
1. First, try resetting the float level to specs.
2. The fuel we're getting today is more volatile and will boil over into the manifold and/or evaporate from the float bowl. An electric fuel pump and pressure regulator is the answer to this problem.
3. Also, as old pot metal carbs lose their plating, fuel will leak through the pores of the casting. This requires a professional rebuild and replating.
jack vinesPackardV8
For $175 and your core, you can't beat T-bow.
Dave Thibeault
13 Nick Lane
Maynard, MA 01754
(978) 897-3158Brad Johnson,
'56 Sky Hawk in process
