I have a 65 Daytona parts car Looks like it was set up for drag racing it has an aftermarket shifter(3sp od) a holly 4 bbl and This interesting rear suspension.Anything here any good for a driver ?Probably a twin trac What ratio? any good whith a 195 six?
What's this
 Teenage kid bolt on stuff.
 Just a pair of Traction Master traction bars (quite a desireable cult item nowadays)
 Overload shocks just tell you the springs are saggy.
 3 speed floor shift gives a kid that hero feeling.
 Intake manifold is probably worth as much as the whole car
 Does the diff have a TT tag, and a ratio tag?
 If not, jack it up (and put it on good jackstands)..
 Stick your index finger in the fill plug. 1 knuckle in=TT ......2 knuckles in= open (non-TT)
 Rotate the driveshaft. Count the number of driveshaft turns it takes to get the tire to rotate one time.
 3&1/2 driveshaft turns? = 3.55 (or so) ratio.
 Nothing there that makes it truly rare, or worth more...
 Maybe just beat up a bit more
 Jeff Last edited by DEEPNHOCK; 08-22-2010, 04:47 AM.HTIH (Hope The Info Helps) Last edited by DEEPNHOCK; 08-22-2010, 04:47 AM.HTIH (Hope The Info Helps)
