Finally got the State sedan up on stands so I could put the new exhaust system on (purchased from Parker Pipes). A rusted up y pipe was all that was left of the old system. After I got it cut off I noticed the heater hoses were shot, so I pulled all 18 feet of it off. Then I noticed the studs on the exhaust manifolds were in poor condition, so they need to come off too......it never ends.....
After I got the passenger side off I saw that the little metal post which holds the end of the spring on heat riser valve was rusted off, letting the valve flop around (the shaft is free & the set screw which holds the counterweight even came out with no problem). So, I'll have to fix that too.
Pulling the drivers side will have to wait for tomorrow. With the power steering unit in the way, it's going to be a pain to deal with..... Hopefully the old studs will come out with some help from mr. hot wrench.
Mike Sal
Mike Sal
