I just replaced the valve cover gasket for my OHV 170 and the valve cover is still leaking oil. I tightened the valve cover so it was snug. How tight should those valve cover nuts be? What else can I do to stop the leaking?
Leaking Valve cover
I've seen some that were tightened in the past to the point where the sides bulge out and warp; sides should be as straight as the heads. I don't have the torque specs handy for the ohv six. Someone should.Brad Johnson,
'56 Sky Hawk in process
Completely clean off any old gasket material from both the rim on the head and the lip of the valve cover with a gasket chisel (your choice). Thoroughly clean the two surfaces with acetone on a clean lint free paper towel. Spray the new valve cover gasket with Permatex Copper Spray-A-Gasket (don't be stingy), hang it on a wire and let air dry for at least 15 or 20 minutes. Apply the sticky gasket to the valve cover and carefully set it in place on the head rim. Tighten the cover nuts moderately. This method has never failed me, ever.Dean
CLEM
