Started working on the engine today to see how good it will run. Found one plug that wasn't firing and the timing was off a little. Correcting these got it running a lot better. Still a little rough but not too bad. Haven't looked at the points yet. I did run it in the dark to make sure the ignition wasn't arching around like a christmas tree. No evidence of archs.
Once it was running smoother I was able to hear a faint knock when I reved up the speed. I can just barely pick it out at idle. Easier to hear when revved up. Must be standing by the engine with the hood up to hear it. Can't hear it inside the car. I went over the block using a big screw driver as a stethascope. Center of the engine, I just hear valve train operation. Knocking noise is more pronounced at the front and rear of the engine.
A water hose blew out and cut my search short. When I get it running again I plan to pull the plug wires one at a time to see if I can isolate a cylinder. Is there any particular spot on the block where I should be listening to help isolate where this is coming from?
When an engine is getting ready to come apart how loud is the knocking normally? Am I chasing something I shouldn't be? I just don't want to end up with a rod poking out the side of my block.
Any advice would be appriciated.
Thanks
Wayne
Thanks
Wayne
