View Full Version : Can't open my hood on '48
kurtruk
04-13-2007, 10:57 PM
So I have this '48 Champion that has been sitting out for about 17 years. I finally got it drug home today. Either the wire has froze-up inside the casing for the hood-release, or the latch plate has rusted to where it won't move. I know it is not broken because it worked fine when parked oh-so-long-ago.
I am aware of the access hole in the plate that provides access to part of the latch IF THE WIRE IS BROKEN. Mine is not. I have pulled very hard on the knob. I am afraid to apply any more force to 59-year-old plastic. Replacement cables are hard to find and $$.
Would someone provide a picture of the top side of the latch plate so I know what I am trying to lever through the hole. And which direction. I tried this many years ago and was not successful then. It is really stuck (rusted?). I have turned the knob as much as I dared in case the wire was frozen-up in the casing. No luck. If the wire is stuck inside the casing, will levering the latch be possible?
HELP! HELP! HELP! I'm stuck--and so's my hood release!
KURTRUK
(read it backwards;))
Anne F. Goodman
04-14-2007, 01:59 AM
http://i122.photobucket.com/albums/o269/nw3anne/02110001.jpg
let me know if this helps . If it doesn't I can take a picture of mine tomorrow for you.
Mabel 1949 Champion
1957 Silverhawk
1955 Champion 4Dr.Regal
Gus 1958 Transtar
Fresno,Ca
http://i122.photobucket.com/albums/o269/nw3anne/Mabel.jpg?t=1165475035http://i122.photobucket.com/albums/o269/nw3anne/xmasannecopy.jpg
kurtruk
04-14-2007, 12:29 PM
Thanks, Anne. But a little closer would help.:) Is that the original configuration for the cable release?
KURTRUK
kurtruk
04-15-2007, 07:06 PM
ANYONE? ANYONE? BUELLER?
ST2DE5
04-15-2007, 07:53 PM
You can trip the hood latch from underneath the front of the car anyway you can on mine. Thats the way I got mine open when I got it.
http://i152.photobucket.com/albums/s197/wagon56/MoparMeet2.jpg
Anne F. Goodman
04-16-2007, 03:25 PM
Ok here's better pictures.
http://i122.photobucket.com/albums/o269/nw3anne/hood%20release/dscn0396.jpg
http://i122.photobucket.com/albums/o269/nw3anne/hood%20release/dscn0395.jpg
http://i122.photobucket.com/albums/o269/nw3anne/hood%20release/dscn0394.jpg
http://i122.photobucket.com/albums/o269/nw3anne/hood%20release/dscn0393.jpg
http://i122.photobucket.com/albums/o269/nw3anne/hood%20release/dscn0392.jpg
http://i122.photobucket.com/albums/o269/nw3anne/hood%20release/dscn0391.jpg
FRom What I saw you have to release it from between the radiator and the grill up from the bottom. Applying pressure from the front to rear to make it release. Hope this helps.
Mabel 1949 Champion
1957 Silverhawk
Gus 1958 Transtar
Fresno,Ca
bradnree
04-16-2007, 08:51 PM
I finally got mine open on a '52. I lubed everything and then ran an extra "cable" attached to the latch, made from wire, from left to right and through a hole in the fender mounting area to come out in the wheel well and then made a loop to help pull it if ever needed. Just another precaution. It works grrrrrrrreat.......Brad
ma1951
04-16-2007, 09:16 PM
I HAD TO OPEN THE HOOD ON MY 49 CHAMPION FROM UNDERNEATH ONE TIME. SEEMS LIKE I REMEBER TAKING A LONG SCREWDRIVER AND BACKING THE PIECE WHICH HAS THE SPRING AROUND OFF TO GET IT OPEN. IT HAS A SLOT IN IT. THIS ALSO DETERMINES HOW TIGHT THE HOOD CLOSES.
